fretting saw recommendations? http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=49899 |
Author: | wbergman [ Fri Nov 03, 2017 2:48 pm ] |
Post subject: | fretting saw recommendations? |
Year ago I got a back saw from LMII that would not cut straight down. I guess the teeth are not offset the same on each side. They exchanged it, but the replacement was also a little off. I have suffered with it, but now I want to get a better one. I am afraid to order one without some recommendations from users. Any recommendations? |
Author: | Colin North [ Fri Nov 03, 2017 7:59 pm ] |
Post subject: | Re: fretting saw recommendations? |
http://www.badaxetoolworks.com/luthier.php |
Author: | Bri [ Fri Nov 03, 2017 8:23 pm ] |
This months FW has a review of 7 dovetail saws. While the kerf may be a few thou. heavy on some, a few minutes with a stone would tune the kerf thickness. The review gave best bang for the buck to the Veritas saw, with the kerf being .027. For the cost of some of the saws, you could purchase a used table saw and a new fretting blade. B |
Author: | Clay S. [ Sat Nov 04, 2017 7:26 am ] |
Attachment: DSCN2143.JPG I use a Makita 50 tooth plain steel (not carbide) 3 3/8 inch circular saw blade mounted in a crude home made tablesaw. They are fairly cheap (about $10) and much faster than the average back saw. |
Author: | roby [ Sat Nov 04, 2017 8:44 am ] |
I use the lmi manual slotting system which works great apart from the saw so i got the stewmac japanese fret saw and i found this to be a vast improvement,no binding cuts like butter highly reccomended. |
Author: | bftobin [ Sat Nov 04, 2017 12:14 pm ] |
I've been using a Lee Valley Veritas saw (I forget which one) and used a diamond plate to take a little off the sides until I got a slot size I like. But, if I had the room, I would make an outfit like Clay S., 'cause that would make life a lot easier. Brent |
Author: | Theo [ Sat Nov 04, 2017 2:35 pm ] |
I've got the manual LMII setup, I can't say that I like it all that much and will upgrade when I can...I had probably done two dozen fretboards and the saw didn't cut well, meanwhile I came across a video on YouTube on how to sharpen saws, well after about 10-15min with a saw file, the LMII saw cut like butter and way better than it ever had, even new. |
Author: | wbergman [ Sat Nov 04, 2017 3:25 pm ] |
Any advice on how to reset the teeth so it cuts straight down? |
Author: | Pmaj7 [ Sat Nov 04, 2017 5:59 pm ] |
Theo wrote: I've got the manual LMII setup, I can't say that I like it all that much and will upgrade when I can...I had probably done two dozen fretboards and the saw didn't cut well, meanwhile I came across a video on YouTube on how to sharpen saws, well after about 10-15min with a saw file, the LMII saw cut like butter and way better than it ever had, even new. Got a link?
Author: | Clay S. [ Sat Nov 04, 2017 7:29 pm ] |
Any advice on how to reset the teeth so it cuts straight down? You could try stoning the offending side : https://www.popularwoodworking.com/wood ... -saw-blade |
Author: | Mark Fogleman [ Sat Nov 04, 2017 10:14 pm ] |
Clay S. wrote: I use a Makita 50 tooth plain steel (not carbide) 3 3/8 inch circular saw blade mounted in a crude home made tablesaw. They are fairly cheap (about $10) and much faster than the average back saw. Very cool Clay! I have an old small benchtop tablesaw which this could work with a 1/2" to 15mm bushing. Which Makita blade are you using and how wide is the kerf? |
Author: | sdsollod [ Sat Nov 04, 2017 10:30 pm ] |
+1 stewmac japanese fret saw |
Author: | Theo [ Sun Nov 05, 2017 2:38 am ] |
https://m.youtube.com/watch?v=_fNosQU1Ujg , I think this was the one. This was my intro to sharpening saws, it happened that I had a little saw sharpening file floating around my shop and it worked great, but I'm not knowledgeable enough to offer any real advice. It is something I hope to learn, when my tool budget allows, a saw set and some more files are somewhere mid-list Edit ![]() |
Author: | nkforster [ Sun Nov 05, 2017 3:21 am ] |
Gary Carter makes a great little saw that uses hacksaw blades. So the blades can be replaced. He does several saws each with a different depth of cut. Great design, I have a pair of them. I use them to check the slot depth but you could use them for fretting. He has some good tools on his site. https://www.guitarbuilding.solutions/pr ... ar-fretsaw I find some of his stuff is well made but sometimes overcomplicated, mind, his string spacing guide is great too: https://www.guitarbuilding.solutions/pr ... cing-guide |
Author: | Clay S. [ Sun Nov 05, 2017 8:15 am ] |
Which Makita blade are you using and how wide is the kerf? //www.ebay.com/itm/Makita-3-3-8-Plywood-Saw-Blade-For-Cordless-Saws-792299-8/292309672794?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D1%26asc%3D20160908110712%26meid%3Dfcf41b7545b34235802af640bfc1feb1%26pid%3D100677%26rk%3D2%26rkt%3D21%26sd%3D291862271905&_trksid=p2385738.c100677.m4598 I haven't measured the kerf, but Stew Mac wire works O.K. with it. |
Author: | wbergman [ Sun Nov 05, 2017 12:18 pm ] |
Am I correct that the teeth are further out on the side that the blade/slot drifts towards? So if my first attempt at correct this is to stone a little off, then I stone the side to which the blade drifts? |
Author: | Clay S. [ Sun Nov 05, 2017 3:41 pm ] |
Stoning will reduce the aggressiveness on the cut so - yes- stone the side it is drifting too. But don't get carried away with it. As with people , if it's too stoned it won't work too well. ![]() |
